will my 2004 megane have an electric handbrake?
edward2
Postby edward2 » Tue May 22, 2012 7:47 pm
will my 2004 megane have an electric handbrake ?
Re: will my 2004 megane have an electric handbrake?
Postby joeishmather » Tue May 22, 2012 8:08 pm
No...
Postby joeishmather » Tue May 22, 2012 8:09 pm
No...Why do you ask? :-)
Postby davelowe » Tue May 22, 2012 9:40 pm
Both are good questions!
I've heard nothing but bad reviews about these latest gadgets. Some French cars have them, but never heard of one on a Megane. That said, the throttle style hand brake is not without its own faults. A triumph of style over design perhaps?
morganjake1544
Postby morganjake1544 » Wed May 23, 2012 5:56 pm
The Scenic (often referred to as the Megane Scenic - it was previously badged as that) has an electronic parking brake. I presume that is where the confusion may have arisen.
ikhan
Postby ikhan » Wed May 23, 2012 9:55 pm
My brother's Passat has an electronic handbrake. If you're a new driver and need to use the handbrake for hill starts etc., then electronic parking brakes won't inspire you with much confidence as you need to have your foot on the footbrake to release the elctronic brake (so you'll be juggling between your biting point / slipping the clutch, and pressing the footbrake whilst trying to release the electronic brake.
On the plus side though, if you attempt to drive off with the parking brake on, it will auto-release on both the Scenic and the Passat.
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
Postby davelowe » Wed May 23, 2012 10:12 pm
morganjake1544 wrote:The Scenic (often referred to as the Megane Scenic - it was previously badged as that) has an electronic parking brake. I presume that is where the confusion may have arisen.
Ah! Did not know that!
morganjake1544
Postby morganjake1544 » Thu May 24, 2012 6:43 pm
That's exactly what it's designed to do - release automatically when you reach the biting point of the clutch. So hill starts in a Scenic are actually a doddle. Just drive off! You've got two free hands as opposed to one holding the handbrake lever. It does feel a bit weird for the first hour or so but I find them better than a standard handbrake.
The other advantage of the electronic parking brake is that it is either 100% on, or 100% off. So no creep on hills. Also, when you stop the engine with the start/stop button the parking brake is automatically applied - you can't forget it.
ikhan
Postby ikhan » Thu May 24, 2012 7:00 pm
morganjake1544 wrote:Also, when you stop the engine with the start/stop button the parking brake is automatically applied - you can't forget it.
I remember that on a friend's Scenic, but I'm not quite so sure the same is true on the Passat though. Mind you, the Passat one can be programmed (after a certain circuit is added) to "auto-hold" when you're stopped...
Lowered 45mm (Spax)
morganjake1544
Postby morganjake1544 » Thu May 24, 2012 7:13 pm
I wonder if these new fangled cars with the fuel saving engine cut out when you're stopped devices have any contingency re braking.
If you stop at an uphill set of traffic lights and your engine stops you must lose servo pressure on the brake pedal and have to 'catch it' or 'anticipate it' with the handbrake. !?
