EGR Blanking
Koreanbaz
Currently Drives:: Renault Trafic and a Honda FireBlade
EGR Blanking
Postby Koreanbaz » Sat Apr 21, 2012 8:33 pm
I've tried the search to no avail.
Can it be blanked off?
My mate has doen his VW Transporter, but I know that the Trafic can't be.
But there is a man selling blanking plates on ebay, So has anyone done it?
Any silly lights or running issue?
Cheers :cool:
Re: EGR Blanking
Postby davelowe » Sat Apr 21, 2012 9:59 pm
If you blank off the EGR on a turbo diesel on a Renault, you will kill it most likely. The least you will expect is all manner of fault codes and lights going off. Why would you want to do it?
Koreanbaz
Re: EGR Blanking
Postby Koreanbaz » Sat Apr 21, 2012 10:16 pm
davelowe wrote:If you blank off the EGR on a turbo diesel on a Renault, you will kill it most likely. The least you will expect is all manner of fault codes and lights going off. Why would you want to do it?
Because the EGR Valve is the devils own work and doesn't actually aid the running of the car, it just aids emissions checks.
But I will look into it futher as suggested.
Koreanbaz
Re: EGR Blanking
Postby Koreanbaz » Sat Apr 21, 2012 10:17 pm
Eddie- wrote:search there was people on here did it casue more hassle than good tbh
off to try again, could seem to get anywhere earlier when I tried though
downsyndromedhorse
Currently Drives:: 3DR Black 1.9dci Megane 04 Plate 120 BHP
Re: EGR Blanking
Postby downsyndromedhorse » Mon Apr 23, 2012 1:53 pm
I've done this, actually made a huge difference. Been done for about 10,000 miles.
Installed a new turbo and decatted at the same time, car is far more free revving and endless power throughout the range.
I left the EGR in and had the pipe between the manifolds removed and welded up. I think it was magnesium weld on the intake manifold because of it being aluminium cast.
Anyhoo, car is driving better than ever, no fault codes and a nice turbo woosh when changing gear from the decat.
So to all those intrigued, yes it works perfectly.
Users browsing this forum: No registered users and 27 guests
