Hello all
My megane has recently started to leak fuel from the tank! If your facing the car the drips coming from the Top Right.
Its never alot that leaks out but its enough to be a problem, ive had the car looked at and they claimed the tank wasnt sealed correctly at the sender so they fitted it back and it should be ok but the leak continued so they had it back again. And again they said its coming from the same place and they have resealed it. But still its dripping
It doesnt drip when the cars sationary with the engine running but if you go out in the car it starts to leak so i belive it has somthing todo with the fuel moving around.
Does anybody have any ideas??
diesel leak
Re: diesel leak
I have to admit that this is a first. How odd. Can you provide more info (although your first post was quite comprehensive).
