Hi
Been looking for information on how to unclip/remove the plastic roof part that covers the pullout blind for the panoramic roof, my blind wont retract and I need to get to it. Help appreciated
Roof lining
- Currently Drives:: Megane 2.0 VVT CC Dynamique
Peugeot 206 1.4 HDI - Location: Paignton Devon
Re: Roof lining
Hi there, kneel on the back seat facing the rear window and you will see two plastic trims above you by the blind going from one side of the car to the other.
Unclip the one nearest to you (the one by the blind) by applying downward force to it at the back in the join between the two plastic trims at about 150 to 200mm from each end.
Once off the blind securing screws can be seen and easily removed.
The plastic trim clips can be quite tight so go easy so you don't damage anything.
