Renault Megane 225 Replica, ph.1
iRenault
Currently Drives:: Renault Megane II, ph. 1 (2004)
Postby iRenault » Mon Feb 13, 2012 10:36 am
Hey there.
I own Renault Megane 2004, ph.1 (engine is 1.5 dci).
I'd like to modify my exterior to the Renault Megane RS 225 look (ph.1).
This includes front bumper, rear bumper and exhaust.
Front bumper:
Rear bumper:
I have few questions:
- if I buy front and rear bumper, will I be able to put them on my car or will I have to modify or buy some other parts as well? (ph.1)
- will the 225 exhaust system (with rear back box or only slip on if I can find one) fit to the original exhaust system? Or any modifications needed?
- some or any links to the needed parts are welcome :)
Thanks for the informations and answers in advance :)
User's signature unvalid.
Understeer is when the driver is scared, oversteer is when the passengers are scared.
iRenault
Re: Renault Megane 225 Replica, ph.1
Postby iRenault » Mon Feb 13, 2012 7:41 pm
What do you guys think about this?
https://www.ebay.com/itm/FRONT-AND-REAR- ... 500wt_1202
Worth buying?
Sadret89
Currently Drives:: RENAULT MEGANE 1.5dci 80, INDUCTION KIT, 8K XENON HEADLIGHTS, 225 SPORT FULL BODY-KIT & EXHAUST SYSTEM, SOUND SYSTEM, TDI TUNING BOX, EDC BLACK STUFF FRONT BRAKE PADS
Postby Sadret89 » Mon Feb 13, 2012 7:49 pm
check my link :-) i have a 1.5dci too
Ashcash
Currently Drives:: '55 Plate Renault Megane II, with plans for modification!! :)
Postby Ashcash » Mon Feb 13, 2012 9:05 pm
I wouldn't recomend those ones on eBay..
First off they're fiberglass reinforced.. Nothing overly 'wrong' with that.. But that's why they"'re so cheap!
Seconly.. If you just get the bumpers you won't be getting half of the pieces you actually need to complete the mod!
For the front.. You need the bumper.. 2 top grills, 1 lower grill, 1 undertray, and 2 arch filler pieces (to ensure a decent fit to the excisiting panels!). Also if you don't have headlight washers.. You need the little blanks otherwise it'll be holy!
For the back you need the bumper and grills
I'd recomend buying these from new @ renaultpartsdirect.co.uk
If you ask you'll be entitled to 10% off for being a member of the forum!
You'll need to order the following bits:
Front bumper kit -
https://www.renaultpartsdirect.co.uk/ind ... t&Itemid=1
Front Undertray with arch fillers. (unfortunately although you get the undertray in the kit above.. You don't et the arch fillers by themselves and buying this tray is the only way (I believe) to get your hands on them! -
https://www.renaultpartsdirect.co.uk/ind ... ct_id=1954
Rear Bumper -
Rear Bumper Grills. -
You can obviously try scouting eBay for bits but they're hard to come by in good nick!
Exhaust wise...
You just need the backbox and tails.. Get someone to weld it on and bosh!
There is a set on eBay at the moment!
Item#.   220950508746
These are available again thought from new.. But a bit of a waste if you only want the tails!
Hope this helps!
As to fitting.. There's loads of show me/tell me's on here.. Just have a hunt!
iRenault
Postby iRenault » Mon Feb 13, 2012 10:44 pm
This is really helpful and just what I need.
Now I'm step closer to finish my replica; thank you Sir!
Edit: Hmm... This would in total cost me about 908£ (1100€) with the shipping (without respray/assembling).
Go me :hm :ohno:
Ashcash
Postby Ashcash » Tue Feb 14, 2012 9:28 am
Your most welcome!
It is a huge expense!
But... You can do what I did..
I went to a special Renault breakers near me and got the rear bumper and grilles plus exhaust for £200 cash
And I'm just going to buy the front kit as I'll never get all the parts I need otherwise!
I'm getting the spraying done by a local bloke in return for doing him a simple website
Fitting is easy as peas just get a mate to help you out offering the bumpers up!
iRenault
Postby iRenault » Tue Feb 14, 2012 3:06 pm
Unfortunately I don't have such a luck, as 225 RS parts by themselves are really hard to get.
Respraying I think won't be such a problem (or cost); the mayor deal is to get those 900£ and getting all the parts unbroken ;)
Thanks for the heads up! :D
Wazzy
Currently Drives:: Renault Megane 1.6 VVT Dynamique
Postby Wazzy » Tue Feb 14, 2012 8:52 pm
Thank You for the Renault parts links! I'm doing the same thing to my 1.6 :)
Such an amazing car.
Ashcash
Postby Ashcash » Tue Feb 14, 2012 9:49 pm
No worries,
Just passing on what I've learnt!
Don't forget to let the forum know how the mod goes with some pics perhaps!!
Sadret89
Postby Sadret89 » Wed Feb 15, 2012 12:01 am
Its a damn expensive modification but transformation is well worth.
iRenault
Postby iRenault » Wed Feb 15, 2012 10:31 am
It is expensive, but I really really want the replica, so I believe those 1k £ won't be that hard to get :)
Questions:
1. I have 5 door model car; do all parts (speaking of front/rear bumper) from 3 door model match my car? :)
2. This question is quite stupid, but anyway: There are two models of Megane 225 (ph. 1, ph. 2) - I know the bunper differences, just: What's difference between Megane 225 and R26? (R26 is ph.1 or ph. 2?)
Thanks in advance :)
Wazzy
Postby Wazzy » Wed Feb 15, 2012 12:41 pm
iRenault wrote:It is expensive, but I really really want the replica, so I believe those 1k £ won't be that hard to get :)
Questions:
Same here, its difficult to insure the real deal and making it a replica just makes the car more attractive for what I feel is a reasonable cost!
I believe the bumpers do fit whether it's 3 or 5 door, wouldn't make commercial sense for Renault to have 2 different sizes.
iRenault
Postby iRenault » Wed Feb 15, 2012 12:58 pm
True :)
Anyway; another question:
For the day lights my Megane has H7 bulbs, right?
What about parking bulbs and bright (long?) ones?
I'll change my stock bulbs to xenon-look bulbs (as xenon kits are illegal; except original ones which I don't have money for).
I was thinking:
Day-lights: Osram NightBreaker Plus H7
Parking lights: either Philips BlueVision or Osram Cool Blue Intense.
Bright (long) lights: Osram NightBreaker Plus H7 (if they match)
Fog lights: Osram All Season
I can take the picture of current park/bright bulbs so you guys can tell me which one are those :)
Thanks.
I just need to buy correct bulbs now :)
Thanks!
Ps. As taking bulbs out/in is really hard at Megane I firstly ask here if anyone knows so I can go and buy them right away :)
Thanks.
iRenault
Postby iRenault » Sun Feb 19, 2012 11:21 am
https://www.ebay.com/itm/220955552400?_t ... #vi-ilComp
Maybe I'll get my hands on this one.
Just, are you sure it will fit my 2004 Megane, 1.5dci? As there it says it won't - but it should ;)
Sadret89
Postby Sadret89 » Tue Feb 21, 2012 10:46 am
Dont buy a original 225 petrol back box!
I did and I noticed a bit of lag and not enough grunt! So I took the back box out and got a custom one suitable for diesels but still kept the original 225 tailpipes
and only cost me £180. Sound and performance improved alot!
