1.9d Lots of white smoke on start up ( sometimes )
needy
Postby needy » Tue Feb 07, 2012 10:14 pm
Hi All
Got a 2002 1.9d
I get lots of white smoke on start up but only sometimes
Can anybody tell me what its from and how i can fix it
Rapidshed
Currently Drives:: 2003 megane dci 120
Re: 1.9d Lots of white smoke on start up ( sometimes )
Postby Rapidshed » Wed Feb 08, 2012 4:10 pm
injectors might be dripping,
basically dripping fuel into pot and come start up it doesn't burn off and comes out as white smoke.
are you also bearing in mind its freezing outside and hot smoke comes out etc more to start with
tomalamix
Postby tomalamix » Sat Mar 31, 2012 10:49 am
you can check the glow plugs also. the car starts fine or it seems there is a "leg" missing?
cheers
Postby davelowe » Sat Mar 31, 2012 10:31 pm
There is a sticky on how to check the plugs - the 1.9 will start fine without them. Very simple procedure with a multimeter. Should be 0.6Ohm between connector and earth. No need for more diagnosis at this stage. Any that read high or shorted are dead. Replace for £10.
If this is not the problem, continue diagnosis (read the manual or ask)!
Users browsing this forum: No registered users and 96 guests
