Headlight auto adjustment?
Disco_Stu
Currently Drives:: Renault Megane sporthatch
Postby Disco_Stu » Thu Feb 02, 2012 11:18 pm
Recently replaced the bulb in my passenger side headlight for dipped beam. I've now noticed that the beam isn't quite right as I see a bright streak of beam in front of it on the road while driving I.e. it would appear that it is pointing downward.
However when parked facing the garage door, the beam doesn't appear to be badly adjusted and after checking that the bulb was in correctly, heard a wiring noise a few times and realised that the headlight unit within the cluster was moving backwards and forwards, zooming in and out like a camera lens if you will.
It appears that it has moved further back than the drivers side unit and the bring line still appears whilst driving.
Is there any way to set this or make it reset itself?
It's an 08 phase 2 model, not Hid, just standard lights.
Any pointers welcome
Stu
Lifes too short to go slow
08 1.6 Dynamique
pwjsmith
Currently Drives:: Megane II
Re: Headlight auto adjustment?
Postby pwjsmith » Fri Feb 03, 2012 2:10 pm
Have you bought the correct bulb? Is the bulb fitted/seated correctly?
Baggieboy
Postby Baggieboy » Sat Feb 04, 2012 12:23 pm
The first time I changed a 'dipped bulb I also ended up with a white streak on the road, I hadn't located the bulb correctly.
'08 1.5dCi Megane CC in Black
