fusebox location and window fault
- Currently Drives:: 54 plate megane 2 estate 1.9 dci
hi all just joined I have a megane 2 estate 1.9dci and cannot locate fusebox just had to change engine as conrod snapped but now my windows dont work ondrivers side front and both front and rear passenger side .... Ive done the reset with switches but still nothing any ideas ????
Re: fusebox location and window fault
location of fuse box behind panel in glovebox and window fault can be fixed by getting a new modulator which is fixed to the motor where the wires go in. clean or repair any corroded wires. to stop this from happening again fix a plastic membrane to inside of door so that your wires are on the outside of the plastic this should stop water getting to them again . RENAULT in their wisdom didnot fit these when they came out of the factory !!!!!!! hope this helps
Users browsing this forum: No registered users and 88 guests
