Steering squeek- VIDEO
STH
Currently Drives:: 1.5 dCi 106 Dynamique, Gold Coloured Bumpers, Rear Parking Sensors, Panoramic roof, CD Changer
Postby STH » Wed Nov 23, 2011 11:01 pm
Okay everyone, long story but you get a video as a treat when you finish reading this.
I got my tyres changed at Kwik-Fit in Norwich last Wednesday 16/11, as I needed to drive to Warwick that evening for a job interview the following day 160 miles.
On my drive I noticed that the tracking had not been adjusted correctly, meaning that I had to drive the car with the steering at a 45° angle in order to keep it the straight line. In addition the car had developed a squeak/chattering noise when you rotate the steering wheel left from centre and all the way to full lock. I then took it to Kwik-Fit in Stratford-upon-Avon who corrected the tracking which inturn sorted that the steering but not fixing squeak.
I've been back to Kwik-Fit in Norwich saying that there is a squeaking coming from when you turn the car to the left and it's only been doing that since the tracking was being wrongly adjusted. They had a look and said that they can hardly hear it and if anything it may be just a bearing in the steering column from wear and tear.
So what are your thoughts?
1.5 dCi 106 Dynamique, Quarts Colour Coded Bumpers, Rear Parking Sensors, Panoramic roof, CD Changer
STH
Re: Steering squeek
Postby STH » Wed Nov 23, 2011 11:02 pm
Rapidshed
Currently Drives:: 2003 megane dci 120
Re: Steering squeek
Postby Rapidshed » Wed Nov 23, 2011 11:15 pm
on your vid it comes across like a clicking kinda noise, like compacting rubber so may well be a worn steering gaiter?
might be worth while getting it in the air and having a mate turn the steering whilst you examin for noises or leaks along the rack
one of mine actually emits a small sqeal/sqeek when turning left and right like a bloody mouse lol.
STH
Re: Steering squeek
Postby STH » Wed Nov 23, 2011 11:56 pm
Rapidshed wrote: like a bloody mouse lol.
like it.
will a single jack give it enough height?
Rapidshed
Re: Steering squeek- VIDEO
Postby Rapidshed » Thu Nov 24, 2011 8:53 pm
yes bud if you have some axel stands jack the car from the centre/front and pop axel stands under either jacking point and take front wheels off, you'll be more than safe on flat ground etc.
just easier to get your head in there to listen close.
STH
Postby STH » Thu Nov 24, 2011 9:51 pm
Rapidshed wrote:yes bud if you have some axel stands jack the car from the centre/front and pop axel stands under either jacking point and take front wheels off, you'll be more than safe on flat ground etc.
Cheers man, I'll give it a look on the weekend.
drom2011
Postby drom2011 » Mon Dec 12, 2011 10:17 pm
ive got the same sound but only when car is on all 4 wheels when lifted off the ground doesnt do it, checked all wearable parts and changed top mounts of sus and still makes sound.
Rapidshed
Postby Rapidshed » Mon Dec 12, 2011 10:35 pm
is this likely to be something to do with steering being electrically assisted? its just both mine have the same kinda noise and again only when on the ground,
the steering is still light with all fluids correct, maybe grease on the steering rack?or the gaitor wearing, its just it sounds more electrical to me.
drom2011
Postby drom2011 » Tue Dec 13, 2011 11:10 pm
mine sounded like it was jumping teeth on the rack really wierd but it has now slightly subsided and is very random now. just given up and put it down to being a renault passed an mot at a main dealer garage the other week that didn't pick it up so cant be anything that bad lol
Rapidshed
Postby Rapidshed » Wed Dec 14, 2011 8:06 am
yep same as me kinda put it down to an issue i'll have to live wth, sadly steering is the only thing letting the car down, just seems vauge and pulls then its fine then it sqeeks its all over the shop lol
