Clutch Pedal
synchro
Clutch Pedal
Postby synchro » Sun Nov 06, 2011 5:01 pm
Our CC clutch pedal was sticky a couple of time yesterday while driving and stayed
down after changing gears. We pulled it up with our feet and it was OK.
Now, today, its doing it all the time and we can't always get it out of gear.
Reading up on the Internet seems it could be a master cylinder problem.
Has anyone else had this and how much ££ did it cost to fix?
Thanks!
Ray
Re: Clutch Pedal
Postby Ray » Mon Nov 07, 2011 6:29 am
sounds like master/slave cylinder problems. not sure on cost though - mine was warranty fix.
synchro
Re: Clutch Pedal
Postby synchro » Mon Nov 07, 2011 5:59 pm
Turns out to be the slave cylinder. £400 fitted, or £1100 changing the clutch at the same time!
Re: Clutch Pedal
Postby Stranger » Tue Nov 08, 2011 1:03 pm
synchro wrote:Turns out to be the slave cylinder. £400 fitted, or £1100 changing the clutch at the same time!
:shock: what?!
I take it that's at a stealers, find a trustworthy independent and, if there's nothing wrong with the clutch there's no point in changing it.
synchro
Re: Clutch Pedal
Postby synchro » Tue Nov 15, 2011 10:04 pm
The slave cylinder had failed inside the gearbox contaminating the clutch.
New clutch nearly £170 and you also need a new mass damped flywheel
at the same time, another £450!
Plus labour (engine out job) just under 1100. That is an independent!
Only problem now is I keep getting engine fault light P0487. It's back in
this week :(
Re: Clutch Pedal
Postby davelowe » Tue Nov 15, 2011 10:25 pm
I've been down this route too. My bill was around £900 (with an indi) but Renault Customer Services paid me £200 in cash, plus a voucher for £700 for future work.
P0487 Generic Exhaust Gas Recirculation Throttle Position Control Circuit
I have no idea whether this is connected to the repair.
Let us know how you go on.
