throttle control fault
Discussions around the Mégane 225.
leefield
Currently Drives:: 225 megane
Postby leefield » Tue Oct 11, 2011 12:28 pm
hi, can somebody please help. I have the engine management light on,as well as esp
Codes in system -
df 079 motor throttle control
df 003 absolute pressure sensor
df 198 pedal circuit track 2 volts low
df 012 sensor supply voltage low
car is in limp home mode. codes have been cleared but returned as soon as the vehicle was started.
Has anybody got any idea's ?
04 plate 225, no mods
Thanx... Lee
Warrender
Currently Drives:: 225 Trophy
Re: throttle control fault
Postby Warrender » Wed Nov 30, 2011 3:04 pm
Hmmm seen as the sensors aren't all directly related id say you've got grounding or water ingress problems mate.
Check your fuse box for water. Pull each multiplug apart and check for water or corrosion.
Check the wires of the individual sensors just to be sure they not trapped anywhere or damaged.I you have a DMM do a continuity check.
After that I'd work around the earth points in the car and clean them, the earth terminals on the cables and the securing nuts, bolts back to bare metal before re-building and cover in copper grease to protect.
Good luck
-W
225djg1st
Currently Drives:: renaultsport megane
Postby 225djg1st » Fri Dec 02, 2011 2:12 pm
had same problem sounds silly but mine was the earth on the battery was loose
Return to “Megane 225”
