1,9 DCI Clutch
ajojets
1,9 DCI Clutch
Postby ajojets » Fri Jul 29, 2011 8:30 pm
The clutch on my 1.9 DCI is slipping, how much of a job is it to change the plate and cover, do I need any special tools other than an alignment tool. :-(
Andy.
tomalamix
Re: 1,9 DCI Clutch
Postby tomalamix » Tue Aug 02, 2011 2:28 pm
the alignment tools and a slippery clutch doesnt have any connection at the first sight. why do you say you could need the alignment tool?
ajojets
Re: 1,9 DCI Clutch
Postby ajojets » Wed Aug 03, 2011 8:08 am
Hi, Because when you take the clutch cover plate off to get at the clutch friction plate , when you put a new cover plate and friction plate in they have to be aligned to the flywheel centre , an alignment tool is used for this, I was asking if any other tools are needed and how much of a job it would be to do at home.
thanks.
Re: 1,9 DCI Clutch
Postby davelowe » Sun Aug 07, 2011 9:26 pm
A big job - axles and transmission out of the car. Not easy without a transmission jack. Plus you have to raise the car very high.
Users browsing this forum: No registered users and 84 guests
