AMP enough power for speakers?
lee3092
Currently Drives:: 2003 Renault Megane dynamique
Postby lee3092 » Sat Jun 25, 2011 2:04 pm
Im thinking of getting a new set of speakers for my car because the paper ones are rather bad and cant handle the bassy music i listen too. for the front im going to get the pioneer custom speakers for the megane http://caraudiosecurity.com/shop/product/products_id/4826.html those ones,
For the rear parcel shelf im thinking of getting these http://caraudiosecurity.com/shop/product/products_id/3817.html.
I was wondering if the AMP that i get with the 6x9's would be enough to power all my speakers :conf
cheers folks
Lee
steve-t
Re: AMP enough power for speakers?
Postby steve-t » Sat Jun 25, 2011 4:56 pm
It's only a 2 channel amp left/right no front/rear so only 2 outputs not 4
So will not run front too
lee3092
Postby lee3092 » Sat Jun 25, 2011 7:31 pm
is there a way i can use the amp to amplify the power from the head unit and also use it to power the 6x9's?
mattyc25
Currently Drives:: megane mk2
Postby mattyc25 » Mon Jun 27, 2011 3:02 pm
why not just put the amp in boot and power the 6x9's straight from the amp?
that way you just need to wire your amp to your headunit via the correct stereo output.? That way if you get a 4 channel amp you can just pull the cars own cables from the rear speakers, wire them to the amp directly, and that way you will have 4 rear amplified?
Matt
