tapping noise on startup
cannocker
Currently Drives:: megan sedan 1.5d
Postby cannocker » Mon May 30, 2011 6:31 pm
On my Spanish Megan 1.5dci, every time I start the engine after 5 seconds there is a tapping noise thet lasts 15 seconds that seems to originate from behind the glove box. Sometimes the same noise happens when the engine is switched off. Has anyone any ideas as to what is causing this noise?
Re: tapping noise on startup
Postby davelowe » Mon May 30, 2011 9:30 pm
Check the oil!
Postby AlexB » Mon May 30, 2011 11:29 pm
The noise can be coming from the vacuum pump, which is on that side.
synchro
Postby synchro » Tue May 31, 2011 9:24 am
mine does this. on mine its a noisy air vent recirc flap.
try setting the air vents to recirc and see if it does it on demand?
monster megane
Postby monster megane » Mon Jun 13, 2011 10:06 am
I was going to say it was the tappets but you say it also makes the noise with the engine off?
tomalamix
Postby tomalamix » Fri Jun 24, 2011 7:54 pm
do you have Auto A/C or manual?
