2003 Renault Megane II, 1.6 16v; For about 6 months my megane keeps going in and out of limp/home mode and displays 'Check Injection' message and lights up the service light.
I have recently changed all 4 spark plugs and all 4 coil packs (which fixed it for around 5 miles).
Does anybody have any ideas of what this problem could be caused by, and if it is a D.I.Y job?
Thank you.
Jamie.
Check Injection, Limp Mode
- Currently Drives:: Renault Megane VVT Dynamique 16v
- Currently Drives:: Mégane III iMusic+
106DCI 6Speed
Re: Check Injection, Limp Mode
have you run the car low on fuel regularly ?? can drag muck from the tank up and cause a blockage in the injectors ...
have you had the fault reset since changing plugs etc....
fault chasing can be frustrating ,cam sensors ,mass air flow meter , dis pack ,egr valve ...and so on
you can have a go at removing the injectors and blowing thru and cleaning with fuel but may need to replace them mate
gooooood luck
gooooood luck
did you find out what was wrong?
