Panel Gap
The section for all Megane III talk.
ahmed24
Currently Drives:: Megane Coupe
Panel Gap
Postby ahmed24 » Sun May 01, 2011 4:37 pm
Can someone kindly measure the panel gap between the wing and the bonnet on both nearside and offside and tell me what the gap is meant to be? i am not sure if my gap is normal.
thanks
Steve-SA
Currently Drives:: Megane III DCI 130
Re: Panel Gap
Postby Steve-SA » Sat May 14, 2011 1:53 pm
5mm nearside
3mm offside
I hadn't noticed this up to now!
Steve
ahmed24
Re: Panel Gap
Postby ahmed24 » Mon May 16, 2011 9:58 am
Thanks for that Steve. I wonder if that is normal? my offside is also slightly more than nearside
copas
Currently Drives:: Megane coupe MK3
Re: Panel Gap
Postby copas » Thu Jul 28, 2011 9:09 am
Hi Ahmed, delay in answer as not been on site for a while,
I found a similar problem when looking to buy a second hand MK3. The panel gap was up to 6mm on one door (door to wing gap) and varied from top to bottom. I went on side of caution and walked away. Panel gap differences can be either a sign of accident damage or just poor quality control in the factory. Phoned Renault who had never seen a specification for acceptable gap (and hinted it was a crazy question!!). Internet searches revealed little on the subject which surprised me as I would have thought this issue would have arisen on owners taking receipt of new cars occasionally (any make not just Renault). I looked at another 6 meganes at a main dealer and found typical gaps of 3 mm but one had 5mm in places. Panel gap is crucial to the quality finish look of a car hence manufacturers try to keep as tight as possible. 3 mm gaps you don’t notice but 5 or 6mm that vary across the panel can be really noticable. My only other guess is that as the doors on coupes are longer than 5 door cars maybe the gap has to be wider to stop the edges catching?. Note panel gap is often referred to as shut gap if you want to do any internet searching.
Maybe the problem is for people like me with an eye for detail!!
Return to “Megane III”
Users browsing this forum: Bing [Bot] and 2 guests
