How to turn off alarm with roof down
- Currently Drives:: megane cc 1.6
Hi to all, im sure this will be an easy one for most of you !, we want to leave the roof down when just nipping around but the alarm keeps going off which means the only way to leave the car is leave it unlocked which is not good, any advise please, the car is keyless thanks in anticapation glen
- Currently Drives:: Renault Megane II 2.0L CC 2003
Ducati 750 SS ie FF 2000
Re: How to turn off alarm with roof down
Hi Amyashley9090,
To turn alarm off with roof down, switch off engine, insert cardkey into slot, press 10 times. If you do it right, when you lock car it will beep (from rear quater) 4 times, this disables the volumetric sensor.
Be aware though, it will reset to normal mode as soon as you open door again, ( which is a apin if you have left something in car
Regards
(this is for the Megane II, I think you press it 5 times for the Megane I)
Regards
