problems with my megane
gordon0104
Currently Drives:: renault megane 1.9 dci privalidge
Postby gordon0104 » Sat Mar 05, 2011 2:08 pm
my renault megan, the message saying check injector's keeps coming on but then dissapearing and yesterday the door lights stay on even when i start the car and drive on, they did used to dim out and go off but wont anymore is there anything i can do to sort this?? i have checked every fuse but nothing!!!
Ray
Re: problems with my megane
Postby Ray » Sun Mar 06, 2011 2:12 am
you probably have dead glowplugs
the lights are on because a floor cubby hole is open
gordon0104
Postby gordon0104 » Mon Mar 07, 2011 2:44 pm
i will have to get the injection inspected properly then..
i have checked the floor cubby holes and there both shut? it happened when i come out of work and my clock/radio had been reset and then the lights wouldnt go off any suggestions ?
Postby davelowe » Mon Mar 07, 2011 10:30 pm
Bit tricky to diagnose without knowing the car model, age mileage, or engine type.
gordon0104
Postby gordon0104 » Tue Mar 08, 2011 1:08 pm
its an 04 plate 1.9 dci privalidge ? if that helps ?
Postby davelowe » Tue Mar 08, 2011 10:46 pm
In that case, Ray is on the ball as usual! Check the glow plug resistance (each should be 0.6 Ohms).
The lights are on because the cubby holes aren't closed (if the catches are broken obtain a new unit from Renault for £28). Easy to fit (3 minute job).
Users browsing this forum: Google [Bot], Google Adsense [Bot], Pipers160 and 65 guests
