Vibrating sunroof
Vibrating sunroof
Has anybody got a fix for a vibrating sunroom please? It rattles like mad and sounds like an old diesel taxi.
Re: Vibrating sunroof
Don't have a fix yet, but mine has developed a rattle in the rear hinge point, drivers side. When the roof is closed and the A/C is on, idle speed is approximately 900rpm which causes the rattle. If I apply upward pressure on the hinge (pushing up on the sunroof), the rattle stops. I think there is either wear or adjustment necessary to the joint.
I was planning on checking with the dealer at the next service.
- Currently Drives:: megane oasis 1.5dci
Iggypop wrote:Has anybody got a fix for a vibrating sunroom please? It rattles like mad and sounds like an old diesel taxi.
I cured mine by tilting the roof,removing the rear pivot torx screw,and made two plastic washers to fit either side of the bracket,greased and refitted,works perfectly with no vibrations or rattles.
- Currently Drives:: Megane II 1.9 DCi
Neil, do you want to do a 'how to' to help those of us who have this problem?
It's caused by the wear on the rubber slider that's at the torx screw. Driving me mad but I refuse to give Renault £90 for a simple little piece of rubber.
55 Plate Dynamique Pearl Black 1.9 DCi, 130 bhp
