how do you take a headlamp out of megane
leighton
Currently Drives:: 2004 megane1.5 dci
Postby leighton » Fri Jan 21, 2011 12:47 pm
i know how to take bumper off but how then do you take headlamp unit out .i know there is a screw at top of unit ,but i can see a long plastic black bit running under the light itself
any help please
Re: how do you take a headlamp out of megane
Postby joeishmather » Fri Jan 21, 2011 1:59 pm
Hi, there's the one on the top, then underneath there are 2 I think, there quite far back, and I think there the same size bolt as the top one, one of the bottom ones is below the outer side of the light and tge other more into the middle, after you have the top one out if you give the light unit a wiggle it should give you a clue to where the bolts are..
Hope that helps.
