Hi All,
I'm a new member and have only had my 2 Lt Auto Megane 05 cc 3 weeks but do have a problem in that both windows have to be held slightly at top when closing doors otherwise windows pop out of seal . So getting round problem when closing doors I have to keep my finger on top of window as I close and when I get in car I have to lower window slightly and then raise this then seals window. Has any one got any ideas how to fix this or is it something I have to put up with. Any help with this would be great.
Windows not closing flush
Re: Windows not closing flush
Hi Got it sorted my mechanic done it shuts nice and flush now without me having to keep finger on window . Had to take door panel off and adjust a bolt inside didn't see him do it just results which is now perfect !
- Napster
- Currently Drives:: Megane Sedan 1.5 dCI 2005
Clio III 1.5 dCI 2007 - Location: Constanta, Romania
Think he tightened the window regulator bolts, 2 on the bottom, and 2 on top.
Renault Mégane Sedan II.1 1.5dCi 82CP 2005 || 93000 km
Hi All just got to problem of windows not only did they not close correctly on openning and closing of doors but one actually failed to come up. Took it to Renault Darlingtons at Harlow and they diagnosed it as a corrosive loom ! due to you gussed it water ingress. However they have been realy good took 75 % off charge and all done next day and now windows open and close correctly and I can shut the doors without holding windows at same time.
