Toxic fume AND service light
- Currently Drives:: 1.6vvt Dynamique
I've read loads and loads about the toxic fume light flashing on these cars. On my one the light is constant and also the service light has come on (it doesn't need a service yet). The car is driving fine as well so I'm a bit confused. Any ideas?
Re: Toxic fume AND service light
I've had this sorted now. It was simply a cam sensor which needed replacing. It was quite a cheap fix.
- pw981
glad you got your problem sorted Ian, what engine is your megane?
2004 Megane II 1.9dCi
- Currently Drives:: renault megane 2 litre cabriolet
hi there chaps having just got my megane cabriolet 3 weeks ago ( 2 litre petrol) it has been in the garage twice up to now with the same fault i.e. check injection and toxic fume light lit up.up to now they have fitted a new throttle housing and then a sensor of some sort total cost to date £385.00 still no better any ideas anyone ..im just wondering if it is because the battery was totally flat when i got it ?.any info would be greatly appreciated
do you have access to some gas analiser? if you have please put your car at steady 2000rpm and post here the gas readings
cheers
cheers
pw981 wrote:glad you got your problem sorted Ian, what engine is your megane?
It's a 1.6 vvti, the one where everything goes wrong and there are common faults on pretty much every part of the car.
sharp_derek wrote:hi there chaps having just got my megane cabriolet 3 weeks ago ( 2 litre petrol) it has been in the garage twice up to now with the same fault i.e. check injection and toxic fume light lit up.up to now they have fitted a new throttle housing and then a sensor of some sort total cost to date £385.00 still no better any ideas anyone ..im just wondering if it is because the battery was totally flat when i got it ?.any info would be greatly appreciated
Did they actually plug it in to a diagnostic reader?
yes they assured me that they had done a diagnostic check which read....fault code po638 (throttle actuator control range performance / isc actuator/throttle motor/app sensor) so they fitted a throttle body.however as this didnt solve the problem the next day they then fitted a new accelerator pedal sensor but sadly the fault is still there.car now booked in at main renault dealers in 2 days time so it will be interesting to hear what they suggest. keep you posted on progress.
I hope they (or you) trace all of the relevant wiring loom tracks for damage. Could be a very simple fault and fix.
Users browsing this forum: No registered users and 22 guests
