Anyone have any ideas if my drivers door speaker not working and my drivers door window not working are related? Do they use the same cabes?
Any help would be appreciated.
Electric Window and speaker malfunction drivers door.
Re: Electric Window and speaker malfunction drivers door.
Please search. You almost certainly have water inside the door. It affects both the issues you mention.
Thanks for that, I'll check the forums for solutions.
There's small drain hole in the bottom of the door check that Its not blocked...
- Currently Drives:: 2006 megane dci
I got the same sorta thing. One min my driver window works and then dont. Today it went down a little and would let it go up. I holded up the button when going over a speed bump and went up. Speaker is fine. Can it be water or wiring came loss. Thanks
Users browsing this forum: No registered users and 67 guests
