I have lost the passenger side plastic panel that you have to remove and change the headlight bulb and renault want £24 plus vat and they only come in pairs any one know where to try? also the aibag and service light is on permanantly any ideas?
vince
megane 1.5 dci inspection panel
- Currently Drives:: Megane 1.5dci 53 Plate
Re: megane 1.5 dci inspection panel
I would get the access hole covered asap as you dont want water getting in there and into the UCH as you will have alot of problems get some gaffa tape and cover it up.
Look like renault have put their prices up they used to be about £15 for the pair, look on flea bay for someone breaking a megane .
As for the airbag and service light check the connectors under the passenger and drivers side seat they are the usual cause
