LED side light bulbs
grosseberger
Currently Drives:: 3 door citrus green Megane II
Postby grosseberger » Thu Aug 19, 2010 8:33 pm
has anyone tried replacing the drivers side side light bulb? i have been able to replace the passenger side but i cannot seem to get at the drivers side bulb any tips or is headlight out?
54 1.5DCI Extreme remapped,JVC Head unit, Pioneer front Kenwood Rear Amp & 10" sub
stu sim
Currently Drives:: renault megane 2003 1.9 DCI
Re: LED side light bulbs
Postby stu sim » Thu Aug 19, 2010 10:01 pm
i done mine by removing the wheel but even at that i had a hellish time trying... try taking some of the wheel arch cover off it might be a bitl less difficult that way .... GOOD LUCK ! they are worth the hastle though once fitted
madwedge
Currently Drives:: 2004 Renault Megane 2.0 litre 16v VVT Dynamique
Postby madwedge » Fri Aug 20, 2010 6:39 am
Hi grosseberger. What LED bulbs have you bought? Do you have a link handy?
Currently Driving: 2004 Renault Mégane Dynamique 2.0 litre 16v VVT
grosseberger
Postby grosseberger » Fri Aug 20, 2010 12:53 pm
These are the ones i brought
https://cgi.ebay.co.uk/Xenon-LED-SideLig ... arParts_SM
Grosseberger
grosseberger
Postby grosseberger » Mon Aug 23, 2010 8:05 am
stu sim wrote:i done mine by removing the wheel but even at that i had a hellish time trying... try taking some of the wheel arch cover off it might be a bitl less difficult that way .... GOOD LUCK ! they are worth the hastle though once fitted
Cheers mate i took the wheel off and the front part of the wheel arch liner then it is quite simple
Postby joeishmather » Mon Aug 23, 2010 8:35 am
i just bought some of these, 6 tiny led's in each http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260644716100&ssPageName=STRK:MEWNX:IT#ht_500wt_1154
£2.50 delivered and they are from uk so only took 2 days!
