can i fit this multichanger
- Currently Drives:: megane dci 120
i work for an insurance compny in their bodyshop this is how i have got an alpine multichanger from a laguna,,,, this is an alpine 6 disc will this work with the stereo fitted to my 2003 megane
Re: can i fit this multichanger
What is the connection type of the multi changer?
it has a multiplug with 10 pins one is not used blank....... the car it is from was on its way to be squashed total loss so was a freebie... it says on the slider renault alpine compact disc changer...on the top s/no al9rn4j0520415
if it isnt compatible with my car its free to a good home or swap for an owners manual
Am I right in thinking this is the Alpine unit with a top sliding door which reviles a removable cartage which 6 CDs can be slotted into?
As it sits in the rear of the phase one Megane ( boot LHS) its only really of use to you or anyone else if you have the matching cable. (2.5 odd meters that links it to the front HU [ISO 80 cable])
Yes you can wire it to your to a standard Meggy HU but the connecting cable is less common that rocking horse sh1T. Although you could fabricate your own if so desired.
If it’s going in the Bin I will certainly pay for postage to take it off your hands!
Regards
Regards
