4 x 100 wheel spacers
Gibzy
Currently Drives:: Megane 2 1.6 16v Dynamique
Postby Gibzy » Wed Jul 28, 2010 12:56 pm
does anyone have the dimensions off of a standard 10mm wheel spacer to suit a 04 megane n 16" nervastellas. i am looking to get a set machined where i work, but need the full dimensions to enable me to do so....
Please please can someone help :grin
Sebring Exhaust,GT valance,-45 H&R springs, 19" Konig alloys
Gibzy
Re: 4 x 100 wheel spacers
Postby Gibzy » Thu Jul 29, 2010 2:22 pm
Bump..... Anyone ???
downsyndromedhorse
Currently Drives:: 3DR Black 1.9dci Megane 04 Plate 120 BHP
Postby downsyndromedhorse » Fri Jul 30, 2010 10:05 am
I believe its a 61mm bore diameter and thats about all i know.
Alex knows many specs on the megane try pm-ing him.
If not, try to find some on google or ebay and find the specs from current ones.
You might need longer wheel bolts if your spacing btw.
Gibzy
Postby Gibzy » Fri Jul 30, 2010 8:40 pm
Cheers, have done the usual ebay/google searching thing.... if im only going with 10mm spacers i shouldnt have to change the bolts.........i dont think ?????
downsyndromedhorse
Postby downsyndromedhorse » Mon Aug 02, 2010 7:55 am
I bought some 10mm spacers for mine, i had a wheel off and put them on and the bolt through, there was about 8-10mm of bolt thread left. I wasn't sure whether to put them on or not, so i left them off and i'm in search of a cheap set of long bolts.
If you do put them on just check whats left and its down to what your comfortable with.
