Camshaft dephaser circuit
CrumpetMonster
Currently Drives:: 2004 Megane Dynamique 1.6 VVT
Postby CrumpetMonster » Fri Jun 25, 2010 12:44 pm
Hi all,
Car is 2004 Megane, 65000 miles, 1.6i.
My ECU has thrown up a DF119/DF080 Camshaft Dephaser Circuit error last week, I've since had the ECU reset and reprogrammed but the problem keeps re-occurring after driving for 20 minutes or so. I'm well aware of the dreaded Dephaser problem and just over a year ago I had the dephaser pulley replaced (cost circa £500 at a non-Renault dealer), so you can imagine I'm fuming at the thought of paying out again the sort of prices one year later. I've also had the TDC sensor replaced about 6 months ago, but I can't remember if I had the camshaft sensor replaced.
Basically, I'd like to know a couple of things if someone would be so kind:
1 - Is there any danger in driving the car with the fault? I've got a fairly important weekend away coming up and I'm relying on it.
2 - Legally, where do I stand if the dephaser was replaced just over 1 year ago and is faulty?
3 - Seriously, is this just a computer issue?
Many thanks, hope you all have a happy shiny weekend :rock
Crumpet
marukas81
Currently Drives:: megane II
Re: Camshaft dephaser circuit
Postby marukas81 » Sat Jun 18, 2011 7:26 pm
hey there everyonee.
my problem is :
once i start ir it revs to 2000rpm then goes to much down to 300 rpm and then rattlessometime cuts off sometime comes to normal idle
if i rev for a while they it come to normal idle stays for 7 9 seconds and engine stops.
if i start it again , it starts norally then after few seconds it stops again ..
i have pain with mine and looks same. basically it three faults:
df80, df81, df154
df80 (camshaft dephaser circuit
df81 canister bleed solenoid valve circuit
df154 flywheel signal senco circuit
i changer flywheel sencor already nothing happens
c0xy
Currently Drives:: megane 1.6 vvt dynamiqe
Postby c0xy » Sun Jun 26, 2011 8:19 pm
marukas81 wrote:hey there everyonee.
my problem is :
df80, df81, df154
replace the camshaft dephaser pulley
from a current renault techichian
Users browsing this forum: No registered users and 92 guests
