atm im running two 12" alpine type r subwoofers with a joint rms of 1000 however they cut out and go into safe mode after my headlights dim. is there anything you could reconmend to stop this from happening.
and then after that would would i need to sucessfully run a second amp to power another 4 speakers with a rms of around 100 each.
cheers for the help
help
- Currently Drives:: Megane II 1.5 DCI
Re: help
another amp deffo.
where have you picked live up from fo rthe amp you alredy have going, and what type of anp is it??
Re: help
atm ive only got the subs actually in my car it was more a question of when i start putting in the other amp and speakers.
o and the live is from the battery and earth on a bolt in the boot
my amps alipne 1.1000 or something like that so its rms is 1000w aswell so it shouldnt be that im over powering the amp.
Re: help
decided its prob best just to get some good replacements for the standard ones instead of replacing them since my headunit powers them at 55rms anyway lol but any help as to stopping this dimming would be good.
the bloke in the audio shop said its cause my subs are drawing to much power from my battry and alternator. if i got a power cap would it stop it? and how would i wire it in lol
was looking at getting this one
http://www.caraudiocentre.co.uk/product_m-in-phase-ipc1d_p-23395.htm
Re: help
mattyattitude wrote:the bloke in the audio shop said its cause my subs are drawing to much power from my battry and alternator. if i got a power cap would it stop it? and how would i wire it in lol
The size of the cap required would be roughly the size of your battery. So, erm, not the solution.
- Currently Drives:: 2008 Renault Megane Tech Run 1.6 VVT
Re: help
i got dual inphaze totaling 1400 rms with a kenwood competition amp, i also have a 1.2 fared but its not powerful enough. mine dims even with the capacitor. only way forward is with a bigger batter maybe a yellow top. or a 2 or 3 fared capacitor but the price you will pay for such a capacitor you will need to pay same price as a good battery. i hope this helps. i use the car audio centre in ilford.
https://www.caraudiocentre.co.uk/product ... -25884.htm
Re: help
ulrich100 wrote:Second battery where the spare wheel goes????
how would i wire it up, got pulled last night for the lights dimming, the cops actully commented on the system and said it was good which i was major shocked about
Re: help
You would wire a second battery with a power line from the original and then earthed to the body.
The amp would be set in series with the second battery.
MAKE SURE IT IS THE SAME SIZE AS THE ONE UNDER THE HOOD. Or over charging can damage one of the batteries.
