No live feed to main bulb cluster
FairyBurst
Currently Drives:: 2007 Renault Megane GT
Postby FairyBurst » Mon Apr 12, 2010 10:08 am
I recently posted about what bulbs should I use for my Megane, however I have discovered it was not the bulb at fault.
After a long process I have discovered that the passenger side side light bulb connector does not have any live feed, the earth works fine. There is not much room to work in this area so any suggestions on what it might be would be most welcome.
I have done the obvious and checked fuses, connectors etc.
Any thanks in advance.
FB.
markren2004
Re: No live feed to main bulb cluster
Postby markren2004 » Mon Apr 12, 2010 11:52 am
have you checked the fuses in the engine bay ? other than that probably a job for an auto electrician
FairyBurst
Postby FairyBurst » Mon Apr 12, 2010 12:11 pm
Mark,
Thanks for your reply. I opened up the fuse box and could not see any blown fuses. I sadly agree with you, unless anyone else has any ideas it will have to go to a garage :(.
FB.
Users browsing this forum: Bing [Bot] and 48 guests
