recaro seats
Re: recaro seats
They will although you will need to take the connection rails off your original seats. It will also give you airbag warning light on the dash as you will be disconecting the ones in the seats. This can be resest,at cost at the local spanner monkey hang out (main dealers)
Re: recaro seats
will the seat be at a sensible hight?
also would an auto electricians place be able to do it or does it have to be main dealer?
cheers
cheers
Re: recaro seats
i just thought of something to add to my previous question,
the seats in mine are just normal ones, not sports or anything, would i still be able to use the runners and subframe off mine??
Re: recaro seats
You can use the same frame. It may just need to be slightly modified. Ie new holes drilled to allow for attachment of the new seat. Maybe a bit of sheet welded on to allow for differeance in attachment spacing.
As to the ride hight i would imagine it will be rather lower. ( probably a good bit lower than the original in its lowest position.) So wont work if your a short arse. Due to the height agustment being part of the seat and not the subframe.
Any other questions just ask.
Re: recaro seats
cheers, mate. im a good 6 an abit feet so should be alright, im alays trying to lower my seat that little bit more!lol
think i may try do this then, i'll let you know how it goes!
