Megane MKII PH2 Headlamps on MKI
frenchie0101
Postby frenchie0101 » Tue Mar 09, 2010 10:51 pm
hi all, im trying to find out if its possible to fit the PH2 Headlamps to the PH1 Model, i did have a good look around but only come across the rear ones which do fit, just to clarify this is for the MK2
downsyndromedhorse
Currently Drives:: 3DR Black 1.9dci Megane 04 Plate 120 BHP
Re: Megane MKII PH2 Headlamps on MKI
Postby downsyndromedhorse » Wed Mar 10, 2010 3:51 pm
Only if you change to the PH2 bumper. If you look at pictures of the PH1 and PH2 from the front, you will see that the PH2 models are at a different angle and won't fit.
There are alot of PH1 headlamp units around though, so there isn't much need to go about replacing bumpers and all.
Nige
Postby Nige » Thu Mar 11, 2010 8:54 am
PH2 Conversion can be done at cost....
STEVIE on here done it to his Megane 230 Replica. Very smartly done too!!!
Postby Paddy » Thu Mar 11, 2010 5:47 pm
Yea as above, PM 'our' Stevie! He will fill you in.
