engine whistles when switched off
milleme
Currently Drives:: megane II 1.9 dcidynamique
Postby milleme » Wed Mar 03, 2010 4:09 pm
Hi all
In the last month or so my 1.9 dci has started to whistle as the engine is shut off.IVe just checked to try and pin point where the sound is coming from and it seems to be from the cambelt side of the engine.
Last summer I changed the cambelt,auxilary belt,tensioner and waterpump and im wondering if the tension on the cambelt could be wrong,the engine runs fine with no noises but as I switch it off theres a very slight whistling type sound which I thought could have been an air leak but I'm not sure now
Any ideas gladly received
Steve
Re: engine whistles when switched off
Postby AlexB » Wed Mar 03, 2010 5:56 pm
How long does it last after switching off the engine?
milleme
Postby milleme » Wed Mar 03, 2010 7:59 pm
Hi AlexB
noise only lasts for as long as engine takes to stop turning so it only lasts 1-2 seconds
Thanks for replying
Steve
STEVIE
Postby STEVIE » Wed Mar 03, 2010 9:56 pm
Hi mate is it the Oil pumping around the turbo to cool it down a bit like a turbo timer
the wife modus does this
steve
Postby AlexB » Thu Mar 04, 2010 10:22 am
Steve and Steve,
There is no timer or anything which keeps the oil pressure on after/while stopping the engine...
The sound can be mechanical, coming from the belts/pulleys/tensioners/mounts, or can be caused by the engine stopping system (the throttle valve with a vacuum actuator). I don't know, to be honest...
direstraits
Laguna III Ph2 Exception
Postby direstraits » Thu Mar 04, 2010 10:45 am
I get the sound of electrics running. Zzzzzzzzzzzzzz. :) But it is perfectly normal. The ECU is still prepared to start the car. It shuts off after a minute or so.
Postby davelowe » Thu Mar 04, 2010 3:06 pm
AlexB wrote:...or can be caused by the engine stopping system (the throttle valve with a vacuum actuator). I don't know, to be honest...
Mine makes no noise after switching off and removing the keycard. However if you stand around for a minute or so, you can hear the cutoff valve snap open again as the vacuum slowly discharges. I don't know either. Plus my noise is from the opposite side of the engine. Could it be the vacuum releasing?
milleme
Postby milleme » Thu Mar 04, 2010 5:31 pm
Thanks for replies Chaps
May be I'm just getting paranoid-I've just recently started getting check injection & service lights come on when engine is cold & glowplugs checked out fine.I'm going to have a look at/change the glowplug relay as the next step.
Also since last year I've replaced the clockspring after it snapped,the battery died with no warning in the middle of summer and the boot lock is having a funny five.....other than that I still think its a great car to drive
All the best
Steve
crackpotterpig
Postby crackpotterpig » Thu Mar 04, 2010 6:06 pm
my 1.9 dci used to make weird noises for a minute or so after switched off its normally the egr or throttle valve cycling :)
Users browsing this forum: Bing [Bot] and 75 guests
