i just scanned my Meggy 1.9Dci 120hp 2005 with ELM327 1.3a and found this errors:
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
P0772 Shift Solenoid "E" Stuck On
B1612 Wiper Rear Mode Select Switch Circuit Open (probably because is wipers are worked)
Could someone with experience can explain what they means ???
Meggy 2 ph1 1.9dci 120ks - Diagnostic Codes - please help
Re: Meggy 2 ph1 1.9dci 120ks - Diagnostic Codes - please help
The first is the boost control solenoid malfunction. There exist other codes for the control being stuck in high or low. Check the solenoid, vacuum pipes/receiver, the turbo actuator, connectors and the valve itself.
The second is the auto gearbox loosing half of its gears. There is not much you can do with it. The dealer can try to release the corresponding clutch by sending command from the Clip computer. ...unless it was an intermittent fault that cured itself.
Before you asked - the repair manual is in our Links.
AlexB wrote:The second is the auto gearbox loosing half of its gears. There is not much you can do with it. The dealer can try to release the corresponding clutch by sending command from the Clip computer. ...unless it was an intermittent fault that cured itself.
huh... i have 6-gear manual transmission !?
sp00ky wrote:huh... i have 6-gear manual transmission !?
For f***s sake!
Does the car drive 'normally'?
Clear the codes, drive for a few miles and recheck. They maybe just stored in memory from time immemorial.
Users browsing this forum: No registered users and 64 guests
