fault code misfire
fault code misfire
hi there new to club can any one help. megane II 1.6 53 reg fault code p0313 misfire low fuel p303 cylinder 3 misfire changed coil pack. car still misfires anyone got any idea what the problem is thanks.
- Currently Drives:: 1.4 16v
Re: fault code misfire
just had a look on a diff forum and found this ...
P0313 = Misfire Detected with Low Fuel
Fill the fuel tank - check fuel filter - do as 91RS states - wires, plugs, coils.
This is really a fuel starvation problem. Fuel pump might be getting lazy but check filter first.
Mez wrote:just had a look on a diff forum and found this ...
If you hadden't stated you read another forum, i would almost think your a renault tech.
DYLAN wrote:hi there new to club can any one help. megane II 1.6 53 reg fault code p0313 misfire low fuel p303 cylinder 3 misfire changed coil pack. car still misfires anyone got any idea what the problem is thanks.
Injector fault since no other cylinders are showing the error?
Keep injectors in mind when suspected coils and sensors drive you crazy. My 1.6 had an electrical fault on an injector causing and intermittant ignition fault.
arnef
arnef
Users browsing this forum: Bing [Bot] and 32 guests
