rear suspension
rear suspension
Hi...I have a Coupe/cabrio...the tyres on the rear have slight wear on the outside edge...the car does not carry loads. Is this a common problem for a 60KLM car...is there a cure, such as stiffer rubber components...is a bit tail happy at best of times..thanks
- Nige
Re: rear suspension
Camber issues sounds like....Suspension may need configured.
- direstraits
Re: rear suspension
Rear axle camber/toe cannot be changed on Megane. Unless you take the whole rear suspension off, like when the rear axle is damaged.
Re: rear suspension
Mine is trhe same, garage checked it last year said with in the limits.
Alan
Alan
Megane CC 1.6vvt and 1.4 clio
