Hi does any one know the correct tyre pressures for my megane 1.9 dci 120 with nervasport 17' alloys?????
Cheers ash
Tyre pressures
- pw981
Re: Tyre pressures
standard pressures for 205/50/17 on a 1.9dCi Megane II are 33psi front, 29psi rear according to https://www.michelin.co.uk
The car users manual may say something else, but I do not know as I've no access to it at the minute!
2004 Megane II 1.9dCi
Re: Tyre pressures
Bear in mind that it depends on load and speed. Generally if you are at motorway speeds and/or towing a trailer, you may need 36psi front and rear.
