My car was not idleing i , check these boards and was correctly advised to remove the battery for 30minutes..it worked perfectly , no idle problem, i enetered the radio code , that was fine problem is electric windows, when pressed it moves up or down as requested for about 5cm then stops , slick again another 5.IT has been obviously reset how do i get it back to one touch movement
Thx in advance
