Performance Air filter problem (ECU Fault???)
Firestorm8
Currently Drives:: megane 54 2.0 dynamique 3 door
Postby Firestorm8 » Sun Dec 13, 2009 7:19 pm
hi all :)
got a megane 2.0 16v 54 reg petrol (LX54ZTT)
Ive tried installing a K&N air filter , which involves removing the ECU from the vehicle AND DISCONNECTION PLUGS.
ive fitted everything correctly on the car and put it all back , but when ive started the vehicle the service light has come on with a computer message saying 'check injection' the car has been limited to 2500 rpm and the max speed ive got out of it is 25-30mph. Im guessing that this is the so called 'Safe mode, which i recall was on the fifth gear 225 review.
Ive read a few forum posts and disconnected the battery for an hour and reconnected it, but this has still not solved the problem . Just wondered if anyone knew about what to do with this ? or whther or not im screwed and guna have to (try) and take the car to a garage ?
any help is very much appreciated =)
thanks Sam (northampton ,corby)
Re: Performance Air filter problem (ECU Fault???)
Postby Anthony » Sun Dec 13, 2009 8:24 pm
Firestorm8 wrote:hi all :)
Is it an induction kit or panel filter?
Firestorm8
Postby Firestorm8 » Sun Dec 13, 2009 8:32 pm
its an induction kit
Postby Anthony » Sun Dec 13, 2009 8:57 pm
Firestorm8 wrote:its an induction kit
Did you disconnect the battery before unplugging the ecu?
Firestorm8
Postby Firestorm8 » Sun Dec 13, 2009 9:13 pm
yes i did
Postby Anthony » Sun Dec 13, 2009 9:24 pm
Firestorm8 wrote:yes i did
hmmmm :? Did you leave it a while between unplugging the battery (10 minutes or so) and unplugging the ecu? I know it takes some time for it to go into a sort of sleep mode.
Other than that do you have a code reader or know anyone who does?
Firestorm8
Postby Firestorm8 » Sun Dec 13, 2009 9:39 pm
well i unplugged the battery , then took about 10 mins tryin to release the battery tray as one of the nuts had corroded : / then i unplugged it from the ecu.
And no i dont kno anyone with a code reader : (
i need the car for work as wel,thankfuly i only live bout 10 mins from work, but i dunno whther i hav to take it to a garage to sort it out
Postby Anthony » Sun Dec 13, 2009 9:46 pm
Firestorm8 wrote:well i unplugged the battery , then took about 10 mins tryin to release the battery tray as one of the nuts had corroded : / then i unplugged it from the ecu.
hmmm I might of been thinking about when turning the engine off before, I'm confused now too! :?
Probably best to get it to a garage. This is the bad thing about modern electronic cars, you can get into a real electro' mess and have no way of knowing what's wrong.
If anyone knows better they will probably pipe up. Sorry I couldn't be more help!
Firestorm8
Postby Firestorm8 » Sun Dec 13, 2009 9:50 pm
nah thats ok, this is my own fault for wanting an induction kit fitted, its the first modification ive done to the car.
what sort of cost do you think I would be looking at ? and is it of any worth gettin a fault reader do you think ?
thanks alot for applying , much appreciated ,btw can any garage test it ? or does it have to be renault ?
thanks again
Postby Anthony » Sun Dec 13, 2009 10:07 pm
Firestorm8 wrote:nah thats ok, this is my own fault for wanting an induction kit fitted, its the first modification ive done to the car.
thanks again
I think most garages would be able to read it, it's essential kit now like I say. You can buy basic code readers for about £30-£40 quid which could be quite useful for future use. If you took it to a garage I don't know how much they would ask, I would guess at not much more than about £20 but that is just a guess, I have never had it done before myself.
Best thing to do is ring your local Renault garage service department, explain what has happened and they will recommend what you should do from here.
Plus you never know, it could of snapped out of it's crawl home mode by morning! Stranger things have happened! :D
Firestorm8
Postby Firestorm8 » Sun Dec 13, 2009 10:23 pm
hmmm oki doke , i will see what my gfs mechanic says n whther he can look at it tomoz. if not looks like im Cycling!!
thanks alot renault :P
ill buy a fault reader tomoz, like you say could come in handy in future.
cheers
sam
Firestorm8
Postby Firestorm8 » Mon Dec 14, 2009 12:28 am
does anybody live nearby to myself and lend me one please : ) would be very much appreciated !
Firestorm8
Postby Firestorm8 » Tue Dec 15, 2009 6:05 pm
got it all sorted in the end, the mechanic diagnosed it n it turns out the car needs to learn how to use diiferent amount of air flow , hes reset the service n everythin seems fine 4 the moment touchwood*
Postby Anthony » Tue Dec 15, 2009 8:15 pm
Firestorm8 wrote:got it all sorted in the end, the mechanic diagnosed it n it turns out the car needs to learn how to use diiferent amount of air flow , hes reset the service n everythin seems fine 4 the moment touchwood*
Glad you got it sorted! Bet it growls now eh?
Firestorm8
Postby Firestorm8 » Tue Dec 15, 2009 8:20 pm
well ive only fitted half of the system and you can already notice a difference. i like it = )
my girlfriend on the other hand says it sounds like the cars broken pffft she can drive where she wants in her own car now. I aint driving her . She obvs wont wana get into a 'broken' car . quite funny actually as shes put a deposit down for a megane!
Users browsing this forum: No registered users and 90 guests
