roof bars
lindalinda1
Currently Drives:: renault megane 1.6 16v dynamique
roof bars
Postby lindalinda1 » Wed Dec 02, 2009 8:00 pm
How do i fit roof bars to my megane II hatchback? please :conf help :conf
Radiv
Re: roof bars
Postby Radiv » Sat Dec 12, 2009 7:17 pm
I guess you need the original ones, and just plug them into the four "holes" in the roof.
andywills
Re: roof bars
Postby andywills » Sun Dec 13, 2009 11:22 am
the little flaps on your roof either pull up or push and slide. remove the plastic caps in the hole and screw bars in. If you don't get all the plastic caps out, you won't be able to fix the screw in correctly, a 6mm tapper will sort that out. You will also find, if you havnt already got them, you'll find that the official renault bars are cheaper than the crap they try to flog you at halfrauds.
