Will Megane F1 wheels fit onto a Megane sport
pager72
Currently Drives:: megane sport
Postby pager72 » Thu Nov 19, 2009 10:15 am
Just after a bit of info. I have just bought a 06 Renault Megane Sport. It has 18" alloy 5 stud wheels on it already, but I want to put on the dark grey Megane F1 wheels.
They are both 18" 5 stud, but Renault say that they will not fit, as the suspension, brakes and fittings are all different?
Is this the case has anyone else done this?
A13XDT
Re: Will Megane F1 wheels fit onto a Megane sport
Postby A13XDT » Thu Nov 19, 2009 10:27 am
I'm pretty sure they do fit. But if not someone will be along shortly to correct me.
Alex
rjacko
Currently Drives:: Renault Megane 1.9 dci Dynamique, 3dr 03 reg
Postby rjacko » Thu Nov 19, 2009 10:55 am
Not done this but I honestly wouldn't listen to the dealers advice as they probably think you've got a non sport model which has the 4 stud hub setup. If your already using a 5 stud setup with 18's you would assume the hubs and wheel stud pcd would be the same but you never know with the french :)
Hope you get them to fit.
Postby Paddy » Thu Nov 19, 2009 5:59 pm
They will fit 100% all measurements are the same.
They wont fit cos the suspension ect is different.... :nut
Man dont ever listen to a Renault Spanner Monkey 9 out of 10 dont know their arse from the elbow. It seems if you have any GCSEs your over qualified to apply to Renault.
rjacko
Postby rjacko » Thu Nov 19, 2009 7:56 pm
:lol: you said it
