i have a 54reg 1.6 megane 4 stud model...
will: 4x100 / 4x108 ET35.........4x 7.5x18".............. FITTED WITH 215/35X18 OR 225/40X18 BUDGET TYRES
fit my car??
help asap please... need to order now
dan
quick confirmation needed please..
- direstraits
Re: quick confirmation needed please..
Only 4x100 will fit.
direstraits wrote:Only 4x100 will fit.
The above is correct, but i think he is talking about one of the multi fitment wheels (multiple bolt holes)
- direstraits
I stand corrected.
defos get 40profiles id go for 225 40 18 if possible as the 40s are bump as hell on B roads and rumble strips are just horrible.
jusr re read that i meant to say get 45profiles if possible, ive got 40s on mine and it seems bumpy on b roads/ bad surfaced roads
Does 5mm really make all the much difference? I know nowt about the subject - just wondering!
- direstraits
Since we're talking of the aspect ratio (40% vs. 45% of 225mm is 90mm vs. 101.25mm), the actual difference is 11.25mm. And that's quite a difference in comfort IMHO. If you put 215/35 you'll have only 75mm of tyre between you and the road. That's a rough ride.
Eddie-- wrote:davelowe wrote:Does 5mm really make all the much difference? I know nowt about the subject - just wondering!
yes depending on the roads really depends on where you drive and the roads
I would never have imagined it would have. You learn something new every day.... cheers!
45profiles cost more thats the only thing, but lowered 45mm theres plenty on room for 45profiles. even with a full load.
