1.6 06 plate megane facelift model how do you reset the service light?
resetting service light on facelift megane ll
Re: resetting service light on facelift megane ll
Get a friendly mechanic with a code reader to list the codes, and then clear them. £20 should be sufficient. Look up the codes online after you have got them to make sure nothing serious is amiss. If they immediately come back, you need to solve a problem depending on what the code is.
- Currently Drives:: Badly
Its the service light, ie reminder, I think you want to reset.
The facelift model does not have the reset button on the dash. Instead flick through the computer on the stalk untill you call up the time to next service, then depress and hold the button, it's straight forward from there.
cyclonebri1 wrote:Its the service light, ie reminder, I think you want to reset.
Oh Cock! Should have read the post more clearly!
davelowe wrote:cyclonebri1 wrote:Its the service light, ie reminder, I think you want to reset.
Users browsing this forum: Google [Bot] and 36 guests
