removing the air filter box
sixtyfivebri
Currently Drives:: megane mk2 1.6 16v dynamique. with panoramic roof and rear roof spoiler. Lowered 30 mm.
Postby sixtyfivebri » Fri Sep 25, 2009 4:33 pm
I am looking to fit a K and N induction kit to my Megane 1.6 vvt, I had a cursory look the other day and managed to easily remove the filter from the air box but can't quite figure out how to remove the airbox, it looks like I may have to remove the battery and what appears to be an ecu ? so I can pull it forward.
Also The throttle body appears to be the same size as the induction pipe so I'm going to have to cobble something together.
Has anyone fitted an induction kit to this model, if so are there any pitfalls to look out for ?
cheers
65B. :cool:
Ray
Re: removing the air filter box
Postby Ray » Fri Sep 25, 2009 6:49 pm
i think it's photo-documented in the mods section... very recently too
Postby davelowe » Fri Sep 25, 2009 10:20 pm
Battery out, battery case out, ECU disconnect and remove, air filter out.
sixtyfivebri
Postby sixtyfivebri » Sat Sep 26, 2009 5:46 pm
davelowe wrote:Battery out, battery case out, ECU disconnect and remove, air filter out.
Thanks for that, I thought it may be the case, but I was hoping that someone may know a shortcut. :)
