ok my megane wont start.
i bump strted it and it was fine?
i changed the battery and starter motor still no difference does any1 have any ideas y my car wont start?
thanks
megane 03 wont start unless bump starteed
- Currently Drives:: "99 1.2 Clio
Soon to be a 3dr megane
Re: megane 03 wont start unless bump starteed
Check fuses/relays?
Is the engine turning over when you press the start button?
its not doing nufin mate no noise or nufin?
Id say check starter motor, or starter relay.
Alan
Alan
Megane CC 1.6vvt and 1.4 clio
thanks everybody for there help...
i changed the starter motor the battery and still no difference i wasent impressed.
sumfin told me 2 check the fuse.!
guess what!
the fuse had gone!
lol
guess what!
the fuse had gone!
lol
Lucky you didn't funk the timing belt!
- Sadret89
also try in future the switch (Grey and green) which is on top of the clutch and brake pedal. My car somehow had them two wires cut so the cars ignition would turn on but the engine wouldn't fire on.
vee wrote:thanks everybody for there help...
guess what!
the fuse had gone!
lol
The words 'school boy error' come to mind!
- Currently Drives:: 2005 Megane 1.5 Dci 5 Door Authentique in Platinum. Mods: TQ-131 Speakers, Aux In cable.
2005 Megane Gran Scenic 1.9 Dci in black. Mods: Aux In cable.
My '05 Megane had the same symptoms after the first month or so, which turned out to be an earthing problem. It could jump start but the ignition wouldn't allow you to just start it as normal. Dunno if that's a common fault?
The Master of Mild Mods!
2005 1.5 Dci 5 Door: TQ-131 Speakers, Aux In cable, upgraded interior door handles and central dash, mock carbon fibre gear knob off ebay, leather gear gaiter and silver sprayed surround.
- Sadret89
Its something between the switch above the clutch and brake pedal and the igintion button, i've cut the switch out and connected the wires together but once I hit 70mph service light comes on and I have to re-earth the wires. AA told me they just need to be soldered togehter. So check your wires don't have any cuts in them and get the switch checked out too.
Users browsing this forum: No registered users and 100 guests
