Having done some searching, there seems to be plenty of topics on changing Headlight bulbs and some on Indicator bulbs but I don't seem able to find anything on changing Sidelight bulbs (specifically on the nearside). Is it really such a hideous job that nobody even wants to mention it or have I just made a poor job of searching? Is removing the Bumper the only way to do this? If so, has anybody got any useful help and tips on doing this?
Cheers.
Sidelight Bulbs
Re: Sidelight Bulbs
My understanding is that there is a removable panel in the wheel arch which give access.
Re: Sidelight Bulbs
you remove the cover by going through the wheel arch, then sort of pinch and twist at the same time to get them out. i've got changing the headlights and side lights down to ten minutes for both sides but tend to have cuts and scratches on my arms. i was considering advertising my services in the local paper but i might end up looking like i'd been self harming
Re: Sidelight Bulbs
the passenger side sidelight you can do from the top, the drivers side is a lot harder but i found "easier" to do from the wheelarch with the wheel off and the top trim removed
- pastymuncher1
- Currently Drives:: megane 1.9Dci
Re: Sidelight Bulbs
Changed my nearside bulb today took 5 minutes, just remove small panel above headlight flat blade screwdriver quarter turn on fixings, then remove panel in inner wing pinch bulb holder and remove . hold up through gap where small panel was removed pull bulb out of holder and replace easy....job.........and i got big forearms..no comments please......
