Reverse light Wiring Colour
Discussions on the Megane II sedan
chavva
Postby chavva » Fri Jul 31, 2009 2:09 pm
Anybody tell me which colour the wire is for the reversing light? I'm fitting parking sensors and I need to splice a feed from the sensor box into the reverse light wire. Any help would be greatly appreciated. I'm having a ' mare. :banghead Thanks!!
Re: Reverse light Wiring Colour
Postby Paddy » Fri Jul 31, 2009 3:26 pm
Cant you just take out the rear cluster and have a look?
or take it from the feed from the rear cluster?
chavva
Postby chavva » Fri Jul 31, 2009 3:45 pm
Ulrich,
Thanks for the reply, however the sensors need to be wired to the reverse light so that they only activate when you put the car in reverse(i.e they only get power when the reverse light illuminates). i hope this makes sense and would appreciate if anyone can give me the heads up.
Thanks again :conf
-KJ-
Currently Drives:: Mégane II Ph.1 1.6 16v Dynamique Luxe, full leather seats, Carminat Informé 1 with CD-changer.
Postby -KJ- » Fri Jul 31, 2009 5:07 pm
According to several forums:
In the black connector: Right side (driver side): pin 2, left side: pin 3.
chavva
Postby chavva » Fri Jul 31, 2009 5:49 pm
KJ,
You are a star! Thanks very much :rock
Postby Paddy » Sat Aug 01, 2009 4:22 pm
You can still take from the cluster... Just trace from the reverse bulb to the correct wires....
-KJ-
Postby -KJ- » Sat Aug 01, 2009 4:31 pm
The black connector connects to the cluster! You can't open the cluster, so the connector is the easiest way to connect your wire to.
chavva
Postby chavva » Sun Aug 02, 2009 2:51 pm
Thanks for all your help KJ and
Ulrich. I just used scotch lock clips to terminal 2(reverse light) and terminal 5(ground) on the driver side(offside). Thanks again!!! :grin
Return to “Megane Sedan”
