hi
Ive been thinking about putting a Eaton m45 supercharger onto my megane which is a 1400cc dynamique can ANYONE give me any tips on what im going to need to do please thanks alot Andy
megane supercharger help!
- preston1234
- Currently Drives:: 54 plate 1.4 16v renault megane dynamique
Re: megane supercharger help!
No one has done this...
You will be the first...
I can't see it fitting in term of space, or the cams, pistons, manifold handling the pressure/forces. Not to mention changing injectors. There by no means built for it...
Good luck all the same I think you will need it, make sure to put up photos of the job.
It won’t be as easy as just slapping on a super charger, a lot of other parts will need replacing (if the replacements for them even exist) If it was me I would save the money and buy a 230 or a new 250. Either of which will work out cheaper I would imagine.
And isnt the M45 rated for 2.0L and above?
And what i remember from uni is a supercharger gives an average of 46 percent more horsepower and 31 percent more torque. -- Buy a 225/230
Although say you get it fitted and it 'works' as soon as you put your foot down some part will go bang no doubt.
- Currently Drives:: 1.6vvt Dynamique
As above, the car will literally fall to pieces and the cost of this will be £4-5k and that's if the parts are off the shelf which I doubt very much. You will need to fabricate fittings, manifolds, brackets etc. etc. Cost could run way way above the cost of a 225 and you will end up with about 150-170bhp for the 5 minutes it will drive for. Good luck though.
Im sure they was someone on the Clublupo site that fitted a supercharger to a 1.4 lupo think it even made it to a magazine spread, have a look at that site.
Goodluck
Alan
Goodluck
Alan
Megane CC 1.6vvt and 1.4 clio
- preston1234
just had a look at the lupo very nice i just wanted to know if anyone had done it or could it be done was going to be an experiment but i think im going to pass
thanks guys
