rattles from the dash
darrenh
Currently Drives:: megan 1.5 dci
Postby darrenh » Thu Jul 09, 2009 7:15 pm
hi all sorry if this has been asked before. have some bad rattles comeing from the dash area access is tight could anyone advise on how to remove centre vent and dash houseing. is there anything ovious.
need to change pollen filter as well every thting seems a bit flimsey and do-not want to break anything.
many thanks darrenh
IainMW
Re: rattles from the dash
Postby IainMW » Sat Jul 11, 2009 9:01 am
Dash rattles are a common problem with Meganes sadly :(
The top part of the dash where the radio display is comes out quite easily; take a firm hold of the cover and lift up and towards the windscreen, the bottom edge should lift out enabling you to get your fingers underneath which helps you even more.
The instument binnacle lifts forwards and up (be careful as the clips can be fragile). Put your fingers at the back and gently prize it up whilst pulling it forwards.
Never had the vents out of mine but took the radio out and plastic cubby hole cover out several times, this has two plastic clips that are easily prized down with your thumbs and it then just pops out with some gentle persuasion.
I found thin foam window draft excluder (from B&Q) to be very good a stopping the plactic to plastic contact that often causes creaks and rattles.
Your pollen filter is located deep down at the back of the dash, look at the back of the centre console from the drivers footwell and you should see a small tab sticking out, this is the filter.
Good luck hunting them rattles! :banghead :down2:
sum-megane
Postby sum-megane » Sun Jul 12, 2009 6:51 pm
darrenh wrote:hi all sorry if this has been asked before. have some bad rattles comeing from the dash area access is tight could anyone advise on how to remove centre vent and dash houseing. is there anything ovious.
many thanks darrenh
Hi darrenh, I am facing the same problem, went to dealer last week for air con, rattles from the dash... as my car is still in warranty... they fixed the air con and totally ignored the noise from the dash saying we cant find anything something like that...
Now today I found passenger electric window not working from either buttons.. now again it will going to dealer garage..... Will it problems ever stop with megane... Sometimes I think I have made a big mistake buying renault car.....
Any comments will be appreciated..... Please let others know step by step if you fix your rattles from the dash...
