How to remove Rear Quater Light Regulator
ChrisM
Postby ChrisM » Wed May 27, 2009 9:18 am
Passenger rear window done with ease!
Regulator bought from scrap yard at £50.
Sorry Can't give Torx sizes as my set is quite old now and sizes on most have gone now.
Steps as folows:
1. drop roof
2. Remove black plastic covers Carefully! at each corner of rear seat by lifting out of rubber seal, pulling towards you and then getting a finger in and pressing upwards on the boot lid side, cover pops off. exposing window lifiting gear and the 2 torx bolts (30's I think) that hold rear seat in.
3. I removed the rear base 1st (Due to rear seat belts)by lifting it slightly then pushing in a large screw driver next to the clips you will see (3 of then) and lifting, you will feel it "pop" out of its mount, lift out base.
4. use a 17mm socket and remove the rear seat belt anchors so the belt is just hanging as you will nee to feed it through the back rest slots.
5. remove the 2 torx screws (30's I think) to release the back rest it will flop forward slightly lift upwards slightly to disengauge the gudies pull both the rear belts out of slots on back rest, rear seat is out.
6. you can now see the rear plastic panel, there are 4 plastic pins holding it in place, but 1st you have to remove the passenger front door trim it runs along the bottom of the door holding carpet in place, it just pulls up and off but it is clipped to the rear panel so you have to remove it, once this is out use a flat blade screw driver to 1st turn the plast pin to release it (it should pop up slightly) use flat blade then to lift if a bit further then gentally prise the round BASE of the pin out, once you get 1 out you will see how it works, panel lifts up to clear the small runner at base of rear window.
7. remove the Electric window switch and rear speaker plugs and the panel will actually rest on the back of the passenger front seat, howeverr I had a twisted seat belt so I took off the lower front seat belt anchor point which is 1 torx 40 I think bolt, push bar back and then pull towards center of car, it is located by a slot and hold fixing the end you can not see it a [ shaped afair you push it back to release it from the hole, then by moving towards the centre of the vehicle the slot allows the anchor the be removed, there fore the whole side panel and be removed from vehicle as well once the seat belt has been feed through the side panel slot.
8. to get the window out - the rubber trim is 1st removed by opening the passenger door and removing the 3 tiny plastic plug clips you cant miss them they are on the large rubber seal next to the rear quater light once these are out, open the boot then you can carefully peel the outer black seal off and the inner rubber seal off, do not try to remove as go into the boot so I took them off as far as the boot and let them sit on the black plastic "parcel shelf" beware there is a little plastic locating clip just under the boot corner this will pop up as well so make sure you mentally mark it so when returning the strip look for it and push it back in place.
9. with the seals out of the way there are in all 3 x 10mm bolts holding the unit in place, so the 1st 2 are visable from the top where the inner rubber seal was the 3rd is hidden inside the panel so you have to carefully remove the grey polystrene cover the get to the bolt and the window power conector, remove all 3 bolts and the power conector , I lifted the window and got the wife to hold it up so I could get the the power plug as it has a little clip on it to hold it in place, once off the window and mecanism lifts straight out as a unit.
10. once out and on the floor you will see there is 1st a mounting bracket which has mounting studs on as well to help position the window unit, to be removed again 2 x 10mm bolts and put onto the new mecanism you will also see the window is held in place by 3 x 10mm nuts I guess you can aslo adjust the window with these as mine was a used one I just replaced the window glass to the same washer marks and tighten it up care again here as I bet you could crack the glass by over tightening them.
11. slot him back in and replace every thing you removed, whilst the little black covers where off exposing the roof mecanism I gave them a spray with silicone grease, and you are done!
Time about 2 hours could have done it possibly 1.5hrs but I cleaned all the rear seats in the places you can't get to and not a £1 coin in sight, very dispointing!
Relativly simple job, looks a mamoth task but it actually not that hard but I supose I was lucky enough to still have my roof working, which made the job simple really, hope this helps some one.
kimyfa
Currently Drives:: Megane II 120 DCI CC
Re: How to remove Rear Quater Light Regulator
Postby kimyfa » Sat Mar 24, 2012 3:35 pm
Many thanks for this great description, worked a treat and saved me a small fortune especially as the mechanism only needed some lubrication
continentalgt
Currently Drives:: Megane 2.0 VVT CC Dynamique
Peugeot 206 1.4 HDI
Postby continentalgt » Sun Mar 25, 2012 8:32 pm
Well done ChrisM this is the sort of useful information we need on this forum, keep it coming :-)
choppybob
Currently Drives:: renault megane cc 1.9 dci
Postby choppybob » Wed Jul 04, 2012 9:45 pm
I have a problem with a rear quarter light that only works with the roof or the center console switch and not the main door switch or it's own switch. Any ideas ?
